09-21-2005 01:13 AM
09-21-2005 01:20 PM
In order to edit scales and ranges you could create a scale and edit the scale on daqmx. Associate the scale with your task and when you edit the scale it should automatically reflect on your task.
The other way to do this would be to use the property nodes for the channels and tasks. This is found under the DAQmx Advanced and navigate to DAQmx constants and propert nodes. You have plenty of options that should help you solve your problem
Prasad
09-21-2005 06:00 PM
09-21-2005 11:10 PM
Dear Ryan ,Prasad
Thanks for the help.Yes I have tried usng property nodes to change the channel scale and range properties.I am yet to test it on the hardware.Also regarding that multiple channels associating to same physical channel.
I am creating tasks in labview using DAQmx and then when i recreate the task using same phusical channel it is not giving any error.Ideally and logcally this should not happen .I am using local virtual channels in the same task.I understand it if it happens in different tasks or different global channels ,but it is happening in the same task.
Regards
Pooja Malhotra
09-22-2005 12:38 PM
