07-06-2009 11:58 PM
As this issue has been risen on LAVA, I checked and didn't find it reported yet.
The issue is when one wants to edit the multicolumn listbox' column or row headers while a VI is running.
By setting the Edit Position property to {-1,0}, it should be possible to edit the first column header. Instead, the {0,0} cell is selected. This behavior occurs also with row headers. The detailed help specifically says that -1 edits the headers and that it's a writable property settable while the VI is running.
The same error occurs with "Table". The only difference is that for tables, there is a "Editable headers" property that needs to be set to TRUE. If false, the edit position returns {-2,-2} as expected. However, when true, it returns {0,0} similarly to multicolumn listbox.
07-07-2009 04:06 PM
Hello normandinf,
Could you attach the VI here?
Which version of LabVIEW are you working with?
07-08-2009 12:34 AM
07-08-2009 12:37 AM
07-08-2009 03:01 PM
Hello normandinf,
Thank you for the report, I've filed a corrective action request (CAR#178213) and our R&D group will be investigating this further.
01-24-2013 04:49 AM
Is this ever going to be fixed in LabVIEW?
It still doesn't work properly in LV 2012....
Thijs
10-23-2014 02:29 PM
It doesn't seem to be fixed in LV14... Is there a workaround?
Cheers
10-24-2014 06:30 PM
Hello Jimmy,
Thank you for your post. This is a known issue in LabVIEW and currently there is no workaround. However, it has been documented and submitted to the LabVIEW Development Team!
Have a nice day,
11-05-2015 08:43 AM
Oh my gosh!
"Known issue" for over SIX years and still not fixed??? What other non-essential "feature" is R&D busy with?...
11-05-2015 12:30 PM
Is there some platform we can use to vote for CAR priorities?
