09-15-2010 07:23 AM
There are some librairies in a server that I'de like to add to my functions palette. So I try the NI method that should be straightforward :
1) Tools > Advanced > Edit Palette Set...
2) Insert > Supbalette... > Link to a directory
3) and I choose the folder...Z:\Labview libraries...
but this works only for the first subpalette, but not the ones beneath... I'm using LabView 2009.
The Z:\labview_librairies folder has .mnu files in each folder. There are many folders and subfolders in the libraries...
Thanks for any help...
09-15-2010 08:26 AM
If you are having the .llb file go to Edit pallete set>> Function pallete>> User Library>> Right click
Insert>> Sub pallette>> Link to an Library>> select the llb you want to add and click save changes.
Before that copy the library file to the user lib folder inside National Instruments >> LabVIEWXX..
09-15-2010 09:03 AM
Thanks for your answer.
I don't have a llb file, the library is made of several directories, main directory is 'Y:\labview librairies'...
09-15-2010 09:11 AM
Is the network drive Y or Z? You said Z initially. Are you sure you're getting it mapped the same way each time you log in? I've sometimes seen cases where a network drive does not come "online" immediately, and you sometimes have to access it via Explorer before the system "sees it". Have you tried copying the files to your local machine and linking there? Do you see the same behavior? Note that it's usually not a good idea to directly link to server resources like that. The library should be source-code controlled and you should be updating your local copy as needed, and LabVIEW should point to your local copy.
09-15-2010 10:38 AM
Sorry for the mistake. The network drive is Y, not Z. I've tried to copy to a local drive, but same problem occurs.
I've tried to delete all the .mnu files in the directories of Y:\Labview librairies and this way it works fine... but... I loose all subpalette Icons defined in the .mnu files...
So, if i link to Y:\labview librairies keeping the original mnu files, I have the problem I described above; If I remove all the mnu files there's no problem, but no icons appear on the subpalettes...
09-15-2010 12:48 PM
Since you have the same issue when you copy the library to your local computer, but goes away when you delete the .mnu files then it sounds like you .mnu files may be corrupt. Try re-creating a few of the .mnu files on your local copy, verify the palette works (restart LabVIEW to check a fresh load), and then copy the library to a temporary folder on the server to see if they still work.
09-15-2010 01:47 PM
Actually if I place a link to the 'Y:\Labview librairies' in the user.lib directory of Labview, it works fine. The palettes appear correctly on the Functions palette (with all icons and everithing) and I have nothing more to do (this when using labview under windows XP). But with this method I experienced some problems with Labview on Windows Vista; it just doesn't work.
The mnu files may be corrupt as you said. I'll try to regenerate some...
Thanks !
Kind regards.
