06-05-2014 01:21 PM
Edit Event Handled by This Case in LabVIEW 2013 does not show Event Specifiers, Event Sources and Events on 800x600 resolution display.
Solved! Go to Solution.
06-05-2014 02:16 PM
Wow, cool. Duplicated it here too...
Mike...
06-05-2014 04:58 PM
I haven't checked specifically, but I believe the minimum supported resolution for LV has been higher than that for close to a decade, if not more. I wouldn't be suprised if NI decided not to fix this.
06-05-2014 05:57 PM
06-05-2014 11:06 PM
Funny, I noticed this same bug when helping my kids program LabVIEW on a netbook (1024x600 resolution) just the other day. I wondered if it had been reported yet, then I saw this post today.
Y'all are probably right that it wouldn't get prioritized too highly since the stated minimum resolution for LabVIEW is 1024x768.
06-30-2014 10:18 AM
I am having the same issue but am limited to an Industrial PC with 800x600 resolution. Is there a workaround for this?
Thanks!
06-30-2014 11:07 AM
06-30-2014 11:17 AM
Dennis, I noticed however when I connect the VGA output of my 800x600 resolution Industrial PC to a much larger monitor I still see the same issue. Do you see that as well? Thanks.
06-30-2014 11:29 AM - edited 06-30-2014 11:32 AM
As far as I know, the list of supported resolutions is determined solely by the display adapter. It's possible that the one used by the PC only supports 800x600 as a maximum resolution, even if you plug in an external monitor.
Like Dennis suggested, the advisable option would probably be to develop on another PC and only deploy an executable to the industrial PC. That's what we do with our systems (although not because of this issue, but because it makes sense. There's absolutely no need to have the IDE installed in most of our systems).
Other possible options:
06-30-2014 12:31 PM
Thanks for everyone's help. I will give that a try
