08-15-2006 06:21 PM
08-15-2006 07:03 PM - edited 08-15-2006 07:03 PM
Just make sure the VI is not set to reentrant (this is the default, so you should be OK unless you changed the execution options). This will ensure that only one subVI call to it can execute at any given moment.
Of course if there is no data dependency, you cannot tell in which order they will be called in each iteration. Maybe that's OK?
You are incorrect to assume that the main VI will pause while the subVI executes. It can easily do other things, e.g. run a paralell loop. However, I cannot make another call to a non-reentrant subVI if that subVI is busy.
Message Edited by altenbach on 08-15-2006 05:06 PM
08-15-2006 08:42 PM - edited 08-15-2006 08:42 PM
Message Edited by unclebump on 08-15-2006 08:42 PM
08-15-2006 11:09 PM
08-16-2006 08:22 AM
This kind of sounds like a producer/consumer architecture. One loop produces commands from multiple sources and passes these commands to a second loop with a queue. The second loop processes the commands when received.
Here are some links to check out.
http://zone.ni.com/devzone/conceptd.nsf/webmain/CD63FD0F746B17A686256F090065F572
http://sine.ni.com/apps/utf8/niepd_web_display.display_epd4?p_guid=B45EACE3E1E956A4E034080020E74861
http://zone.ni.com/devzone/conceptd.nsf/webmain/4C94C56FE0BBF5F686256A2C006C139C
http://zone.ni.com/devzone/conceptd.nsf/webmain/C54BADADD8BBDE4286256C5200533B80
http://zone.ni.com/devzone/conceptd.nsf/webmain/91cbfbd333e64aff86256d5500463b37
08-16-2006 08:31 AM
I'd just like to clarify altenbach's response. I think he was answering under the assumption that you had mulitple calls to the SAME subVI. If this is the case, his response is correct.
The way I read it though, you have DIFFERENT subVIs that all interface with this instrument. In this case, even if the subVIs are non-reentrant (default), one could begin execution, grab ahold of the instrument, and then a different one could start running before the first one finishes, which sounds like it could be problematic for you.
It sounds like you should just be serializing your subVIs, either with dataflow (just wiring error out of one to error in of the next, for example) or with a sequence structure.
08-16-2006 09:46 AM
Yes, my anwer specifically deals with different instances of the same subVI. Reading the original question again, this may, or may not, be the right answer. 😉
(If all the subVIs are very similar, one could combine them all into one and use e.g. an enum input to select the sub-function (e.g. read|write|reset). Now my advice will still work).
If they are different subVIs, dataflow is the way to go. Any well designed instrument VI has an error-in and error-out. Chaining them up in the desired order is all that's needed to enforce serialization. 😄
08-17-2006 10:15 AM
