01-09-2015 01:47 PM
I am trying to take temperature data from with an agilent 34970a through labview. I wrote a pretty simple program to do this every 10 seconds and it works, but when I compare the data taken to data taken using a different data logger the data doesn't match up. The labview data is incorrect. For instance, if I put the thermocouple in the freezer at -8 C the labview data only reads out 2.5 C. Has anyone else had this problem, is there a bug? is there something I am missing for the code to be more accurate?
01-09-2015 02:21 PM - edited 01-09-2015 02:26 PM
I don't have 2014 at work yet so I can't look for scaleing errors but, it is almost certain LabVIEW is not changing the data it gets from the DAU. Likely, something is introducing an error in your measurement.
Possible sources:
Easy quick and dirty test: grab a cup of ice water and measure that until it stabalizes. That should be a reading fairly close to 0C.
01-09-2015 02:29 PM
