05-20-2016 05:47 AM
Hi Guys
I bought a LabVIEW 2014 for Education Licence.
Now I would like to program a LEGO EV3 brick.
But when I want to start a new program, I'm only able to connect to a LEGO NXT brick.
I tried to download the newest addons from LEGO, but it doesn't function.
Can you give me an advice what to do?
Thank you in advance.
Solved! Go to Solution.
05-23-2016 03:19 AM - edited 05-23-2016 03:36 AM
Hi Bunraz,
which downloads did you try? This one for EV3?
Community: NI LabVIEW for LEGO® MINDSTORMS® / LabVIEW Module for LEGO MINDSTORMS - Download - National Instruments
https://decibel.ni.com/content/docs/DOC-15615
and then the following link?
LabVIEW 2014 Module for LEGO MINDSTORMS - National Instruments
http://www.ni.com/download/labview-nxt-module-2014/4761/en/
Can you give me a detailed description about what is not working? Or a small step by step of what you are starting?
Can you attach a screenshot of the parts that are not working?
Most of the examples you find in LabVIEW are valid for NXT and ev3, so e.g. go to
LabVIEW >> Find examples >> Toolkits and Modules >> NXT Robotics >> Display >> Simple Display.vi
and run it, when your EV3 is connected to your computer with USB. it should simply start up.
Cheers, Niko
05-23-2016 10:05 AM
Hi NikoNR
Thank you for your answer.
In the meanwhile I found out, that i needed to reboot my PC, after installing the addon.
Cheers, Bunraz
05-23-2016 10:09 AM
Hi Bunraz,
good to know the problem is solved!
Ciao, Niko
