ERROR:MapLib:979 - LUT4 symbol
Hello DDAAMMIIR,
Are you using any CLIP nodes in your project?
If yes, then you should change the "VHD" capitalization in the xml-file related to the CLIP node to a lower case "vhd".
If you are not using CLIP nodes, then this work-around will not be of any use.
In this case, please create a new forum topic.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 21 of 23
(671 Views)
Thank you for your response,
but, I don't have CLIP nodes in my project.
So, I need further research about my problem.
King Regards
Message 22 of 23
(658 Views)
If you do not have a CLIP node in your project, then I would suggest you start a new/different forum thread.
Please also include in this new thread any code that is necessary to reproduce the issue.
Kind Regards,
Message 23 of 23
(638 Views)
