ERROR:MapLib:979 - LUT4 symbol
When I try to compile my LV FPGA code (using LV 2010) I get the following errors: (In LV 8.6 It worked great....)
Code:  LV FPGA code problem
   "LvFpgaWindow/theVI/leds_array_ind_0/PlainIndicator.PlainIndicator/cQ_mux0000
   <0>1" (output
   signal=LvFpgaWindow/theVI/leds_array_ind_0/PlainIndicator.PlainIndicator/cQ_m
   ux0000<0>) has input signal
   "LvFpgaWindow/theVI/n_While_Loop_7892_Diagram/n_NiFpgaAG_00000008_SequenceFra
   me_Diagram/n_nirviEIOImplementation_xnode_91_Diagram/cSyncRegister<7>" which
   will be trimmed. See Section 5 of the Map Report File for details about why
   the input signal will become undriven.
   <1>1" (output
   ux0000<1>) has input signal
   me_Diagram/n_nirviEIOImplementation_xnode_91_Diagram/cSyncRegister<6>" which
   <2>1" (output
   ux0000<2>) has input signal
   me_Diagram/n_nirviEIOImplementation_xnode_91_Diagram/cSyncRegister<5>" which
   <3>1" (output
   ux0000<3>) has input signal
   me_Diagram/n_nirviEIOImplementation_xnode_91_Diagram/cSyncRegister<4>" which
   <4>1" (output
   ux0000<4>) has input signal
   me_Diagram/n_nirviEIOImplementation_xnode_91_Diagram/cSyncRegister<3>" which
   <5>1" (output
   ux0000<5>) has input signal
   me_Diagram/n_nirviEIOImplementation_xnode_91_Diagram/cSyncRegister<2>" which
   <6>1" (output
   ux0000<6>) has input signal
   me_Diagram/n_nirviEIOImplementation_xnode_91_Diagram/cSyncRegister<1>" which
   <7>1" (output
   ux0000<7>) has input signal
   me_Diagram/n_nirviEIOImplementation_xnode_91_Diagram/cSyncRegister<0>" which
Any advice???
Thanks very much!
Vincent
Message 1 of 23
(8,011 Views)
anyone?
Message 2 of 23
(7,976 Views)
When using Xilinx Tools the synthesization works fine... Anyone?
Message 3 of 23
(7,852 Views)
Hello Vincent Claes,
I've looked in our database and found a similar problem.
Can you please take a look at the following link: http://digital.ni.com/public.nsf/allkb/BB56082D6A521196862574DC006BE858?OpenDocument
Can you tell if your target is supported?
Kind regards,
Nico Lammens
NIBE Applications Engineering
Message 4 of 23
(7,834 Views)
Hi Nico
The strange thing is I have implemented this design using the VHDL code and Xilinx ISE tools and this integration is working. When using the LabVIEW FPGA module/CLIP node it is not working... Maybe some features of the CLIP node are not supported for this Xilinx Spartan3E Starter board ???
Message 5 of 23
(7,754 Views)
Hello Vincent,
You mention that you ahve implemented this already with the Xilinx ISE Tools.
By this you mean without using LabVIEW FPGA?
Which version of the Xilinx ISE Tools did you use to implement this without LabVIEW?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 6 of 23
(7,624 Views)
Hello Vincent,
You mentioned that you have implemented this already succesfully with the Xilinx ISE Tools.
Kind Regards,
Message 7 of 23
(7,623 Views)
ISE 12.3, but it is possible with all versions of ISE I think...
Message 8 of 23
(7,597 Views)
The default compilers used for the Compilation of a LabVIEW FPGA 2010 VI are the Xilinx ISE 11.5 and Xilinx ISE 10.1 (depending on which kind of target you are using).
It could be that the functions you're trying to implement are not supported by ISE's older than 12.x .
Which FPGA target are you using?
Kind Regards,
Message 9 of 23
(7,590 Views)
my target is a SPARTAN3E FPGA (from the Xilinx Starter board)
SPARTAN3E devices are supported from ISE version 7.1 and up
You can try to open http://pwo.fpga.be/LabVIEW/ (solution lab 4 that worked fine on LV 8.6)
If I try to reopen the solution in 2010 I doesn't work anymore so it's probably an issue on the NI LV backend of LV FPGA
Message 10 of 23
(7,586 Views)
