EIOXNodeErrorStruct.ctl exits labview when selected
Hello there,
Just like the title already says, I have some software that a person before me made using the cRIO 9101.
Every time I try to open the software it is asking me to point out some .ctl files.
When I am searching after them on my hard disk, I am selecting them.
And every time I select the EIOXNodeErrorStruct.ctl then the labview gives the error I attached and just closes...
Is there anybody who ever had something like this?
What should I do against it?
Thanks in advance for the help.
________________________________________________________________________
Problems will keep comming... Lets hope the answers do that to.
Never give up without a fight...
(2,290 Views)
Hello J.Willems,
Do you have information about the LabVIEW version in which the original application was made?
Do they use self-made XNodes in this application?
Is it possible to share the application/code with me?
Which NI software set-up are you using?
If you could share a MAX Report with me, then this might provide me with some valuable information:
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,217 Views)
Hello ThiChop,
I completly reinstalled my labview setup, and now the problem is solved.
The persons from NI Belgium think it is there was a problem with one of the dependencies.
Now I can open and run the program.
Thanks for the reply.
(2,212 Views)
Hello ThiChop,
(2,212 Views)
Hello J.Willems,
Thanks for letting me know!
Alot of success with all your programming!
Kind Regards,
(2,202 Views)
