07-26-2016 05:44 AM
Share the code which you tried.so that you will get the exact solution.
07-26-2016 12:24 PM
I am attaching my code snippet and the error.
07-26-2016 12:59 PM
The error is solved. I am posting my new code. But it is not opening the VI. I ran the VI with 'Highligh execution'. The program is not coming out of the Pass by reference node. It is stuck inside the pass by reference node.
07-26-2016 01:02 PM
Sigh. Time to Rant and Rave again. Showing us a picture of part of your code is almost useless to us. Think about it -- you have a problem with your code, you don't know where the problem is, so you show us a tiny picture of part of the code, which may well be far away from the True Problem (and, in your case, almost certainly is), and are frustrated when we can't quickly "fix it" for you.
So let me tell you exactly the steps to follow to get all of your code to us, so we can look at it all, understand where the Coercion Dots (did you see those?) are arising (and causing your error), and can suggest solutions.
07-26-2016 01:13 PM
Thanks for the fast reply. I am attaching the two VIs. The maintest.vi is run first. When I press OK Button, it should popup the camsetv1.vi and run it. It should pass two Unsigned 32 bit parameters to the new VI. The camsetv1.vi have an infinite while loop in it.
07-26-2016 01:38 PM
Huh? There is no OK button, there is (in Main Test) no calls to camsetv1.
Oops, I didn't see the "orphan" Case Statement below the While Loop in Main that's trying to open "delay.vi" (which does who-knows-what).
I don't know about my colleagues, but I'm getting frustrated by the amount of time I am wasting trying to help you when you won't do what is necessary for us to be able to do so. I'll repeat and expand on the first part of my request:
I'm guessing that you created a Passbyreference folder, put two VIs in it, and sent that along. No, that's not helpful (to us, and ultimately to you). Take your existing folder, even if it is messy, has lots of "junk" in it, etc., compress it, and attach it. [OK, you can clean it up a little, but before attaching it, be sure that the code inside the folder is complete and illustrates your issue!]
Note that aside from the inoperable Run VI Invoke Node in MainTest, I saw nothing related to Dynamically Open VI and passing a parameter to the dynamically opened VI in what you sent.
07-26-2016 01:52 PM
Oops, LabVIEW is saving the VIs at random locations, messing things up. Please find the new attachment. The camsetv1.vi calls some library functions which helps to talk to our camera.
07-26-2016 02:01 PM - edited 07-26-2016 02:04 PM
Dude...
Clearly LabVIEW asked at one point where you wanted to save dllreg.vi and you told it to save at C:\Users\Skaria\Desktop\Fastec\LabVIEW\dllreg.vi. It wasn't random and it isn't messing it up.
In addition to this you seem to be missing unreg.vi, camreg.vi, camunreg.vi, and camset.vi in your zip.
As far as calling camsetv1.vi I think you have it done right with the strict VI type matching the one you specified, but why are you doing this in the first place? Is there something wrong with just calling the sub VI instead of calling it by reference? If you are meaning to make multiple windows of this VI you'll need to perform a call and forget. Calling it by reference like you have will do the same thing as calling the sub VI statically.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
07-26-2016 02:05 PM
I want to popup camregv1.vi. I addition I want to pass two parameters to the VI. Invoke node allows me to popup the camregv1.vi . but it will not take any parameters.
07-26-2016 02:29 PM - edited 07-26-2016 02:30 PM
If you are using the invoke node method you can set the control values using other methods before invoking Run. Of course the more modern way is to use static VI references, and the Start Asynchronous Call. Take a look at this example I posted a while ago.
Run the Launch.VI and it will open N new windows. If you add inputs to the terminals of the Reentrant.vi they will show up on the terminals of the Start Asynchronous Call and those inputs will be used when that instance of that VI is ran. This works by using static VI references, with the type included. This also has the added benefit of not caring on disk where the VI is stored. When making an EXE the VI is included in the EXE and used.
