01-19-2017 03:44 AM
I want to create a freehand ROI descriptor.
The coordinate of boundary points are stored in a text file in the following format:
x1
y1
x2
x2
_ I have trouble reading the points since the Read from spreadsheet file VI seems to create a 2D array when the required contour array is 1D array.
_ Also, i cannot create a proper cluster for the ROI descriptor. Please help me with this also.
Thank you in advance!!!
01-19-2017 08:26 AM
OK, so you have multiple X-Y points. You need 1 dimension for saving X and Y, and if you want to save more than one point, you need a second dimension to save points.
Yes, your "contour" is an array of "points", but each "point" is a 1D thing (unless you represent it as, say, a Cluster, in which case you could have a 1D Array of Clusters).
01-19-2017 09:13 AM
Hi Bob,
Thank you for your reply.
If that's the problem, can you suggest any suggestions that those points' coordinate can be pushed into the ROI descriptor, let's say i can re-format the coordinate txt file as convenient as possible.
Thank you in advance.
01-19-2017 11:06 AM
Hi
Thank you for your help, i found a way to programatically read the coordinates.
However, it keeps on saying my "Roi descriptor" is invalid although it seems quite valid to me since i resemble the same method from another program and the value displayed seems to be what i expected, here's my VI.
I'm sorry i cannot provide the picture since it's quite large.
