01-16-2007 11:12 AM - edited 01-16-2007 11:12 AM
Message Edited by ADAC on 01-16-2007 11:14 AM
01-18-2007 04:39 PM
Hi ADAC,
The short answer is no, you cannot do this. If you set the "Open VI Reference" option to 2, you can open the template itself and this will not have this problem. But if you need to create new instances of the template this will not work for you. You may be able to "work around" this (even though work around is a dirty word). It might be possible to programatically make a copy of this VI on disk and then programatically edit the lvlib file such that your new file is a member of the library. I haven't tried this myself so I'm not positive this would work but it might.
I hope this helps,
Justin D
01-19-2007 11:21 AM
Thank you for your reply.
I have a couple workarounds (dirty word!) in mind already, but they really go around my whole programming structure - eck. That's life!
