Dual Numerical Control Change
Dear Friends
I have two Numerical Control in the FrontPanel. Now I want to program Numerical Controls such that when I changed one of them the other one change susequently.
for example in the attached VI when I set "A" to 1 "B" should be automatically 1 to and when I changed "B" from 1 to 5 "A" Should be changed to 5 automatically.
Sincerely V.S
(2,832 Views)
Hi VS,
use an event structure and a value change event for each control…
(2,826 Views)
Dear GredW
Could you please explain more?
Regards
(2,800 Views)
Accepted by topic author V.S
Hi VS,
that's what it looks like for a value change event of "A":
Btw. is it that hard to spell my name correctly?
(2,793 Views)
Dear GerdW
So sorry for misspelling
Thanks for the solution.
Regards
(2,781 Views)
Dear GerdW
The suggested solution works but when I change the data several times in a row it hangs and I can not input new values any more.
Please see the attached file.
Regards
(2,773 Views)
Hi, V.S
You have too much event structure in while loop.
It will run step by step.
For example, when you change value A , and it will run "A" event but the last three event wait for user changing value.
The program is not to work, because it wait others event occurs.
You can add more case in one event.
Patrick
Certified LabVIEW Developer
(2,761 Views)
