NI Home
Cart Cart | Help
You are here:
Reply
Member
Peter Saraiva
Accepted Solution
Drop-down menu
I have to communicate in modbus with a machine which is in ASCII, so I want to create a drop-down menu within all the ASCII command.
Any Idea ?
thanks
Peter.
Labview 2010
Active Participant
P@Anand
Re: Drop-down menu
You can take all the commands into Ring control and pass the values using the property nodes.
I don't believe in Hard work. I love my work :smileyhappy:
Proven Zealot
Re: Drop-down menu
Hi Peter,
"Any Idea ?"
Yes: take a dropdown menu (aka Ring) and input all your "ASCII command"...
What answer do you expect? Just create the menu!
CLAD, using 2009SP1 + LV2011SP1 on WinXP+Win7+cRIO
Kudos are welcome :smileywink:
Member
Peter Saraiva
Re: Drop-down menu
I don't really know,
In fact, in the drop down menu I want to put the instruction (example : Move to the first position) and when this case is chosen we send the ASCII code of this instruction to the machine..
Peter.
Labview 2010
Active Participant
P@Anand
Re: Drop-down menu
If that is a big instruction then you can go for Enum so what ever you want the desciption of the command put it into Enum so correspondingly in case structure you can send the command.
Proven Zealot
Re: Drop-down menu
Hi Peter,
"when this case is chosen we send the ASCII code"
Well, that sounds like the perfect use for a case structure, don't you think?
Member
Peter Saraiva
Re: Drop-down menu
Yes of course I'll use a case structure.
but in what kind of variable should I put my string command ? and where can I find that ? knowing that the command are in ASCII
Peter.
Labview 2010
Proven Zealot
Re: Drop-down menu
Hi Peter,
- LabVIEW doesn't work with variables...
- when you need "ASCII commands" I would use a string constant...
Member
Peter Saraiva
Re: Drop-down menu
Ok, sorry I'm a new user of labview lol :smileyembarrassed:
Thank you for your help;
Peter.
Labview 2010
Proven Zealot
Jeff·Þ·Bohrer
Re: Drop-down menu
Actually-  This sounds like a great use for a combo box.  They are a littel under used but can very easilly map a pairs of strings.  Display "Human readable" and value in ASCII.
"All shall be well and all shall be well and all manner of things shall be well" -Julian
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
