Download LV 2011
i registered my LV2013 online on NI-Website but there is can only download LV2012 under past-versions.
Where can i get LV2011?
Thanks for help
Message 1 of 9
(3,516 Views)
Hi One,
don't you think discussing license questions should be made at best with your NI customer support by a quick phone call?
Message 2 of 9
(3,513 Views)
I thought the solution is a simple link to a ftp-server that someone can post.
Message 3 of 9
(3,510 Views)
I found the English version here: http://www.ni.com/download/labview-development-system-2011-sp1/2871/en/
GCentral
Message 4 of 9
(3,481 Views)
Hello to all
LV2011 32 bit ger
LV2011 32 bit eng
LV2011 32 SP1 ger
LV2011 32 SP1 eng
hope this helps
normally all should be found on our webside
best regards
Alexander
Message 5 of 9
(3,449 Views)
I only see 2012 and 2013 on this page:
Message 6 of 9
(3,437 Views)
Read the text in the green box above the list!
Message 7 of 9
(3,430 Views)
I says "register your serialnumber" - This is what i did before posting the picture.
Before that i also couldnt download lv 2012/2013. After registering only those two versions appeared.
Message 8 of 9
(3,420 Views)
I suppose that you SN is only valid for these versions from your picture.
Contact support from NI as Gerd already wrote.
Message 9 of 9
(3,411 Views)
