Downconverting Lvlib
Hello all, I have to programatically downconvert a bunch of VI's from LV 2009 to LV 8.2 , so I am using "Save for Previous" invoke node by getting the VI Server reference of the particular VI (as shown in the figure) . This has to be done for the lvlib also, but by getting the Library reference I cannot able save to the Specified version, it only has got an option to Save for the immediate previous version. Any idea how to save the lvlib from LV 2009 to LV 8.2 programatically ?
Downconvert
AshwiN,
Message 1 of 12
(4,555 Views)
Hi Ashwin S,
you can read all objects from this library and store it as single vi's. If you have the path to the single vi, then it should work as for your other vi's.
Mike
Message 2 of 12
(4,542 Views)
That's fine Mike, assume that I have to down convert the Entire folder to LV 8.2 which contains lvlib, lvproj, VI's and controls. I can able to convert all the VI's and controls from LV 09 to LV 8.2 (through that invoke node), but the problem is about converting the Lvlib straight away to LV 8.2. Can you suggest me any solution for downconverting the Lvlib from LV 2009 to LV 8.2 programatically
AshwiN
Message 3 of 12
(4,537 Views)
Hi Ashwin S,
i'm not sure if it is really necessary to downconvert the lvlib itself! It's "only" an xml file which contains the pathes of the vi's.
Hope it helps.
Mike
Message 4 of 12
(4,525 Views)
AshwiN
Full disclosure:
I am not an expert so I may have missed something...
I tried to back-save and lacking passwords, LV will not let do so. This makes sense since not all in the current version of LV is possible in the previous.
You can get all of those from an install of LV if all els fails.
Ben
Message 5 of 12
(4,519 Views)
Hope it helps.
Mike
Hello Mike,
If I  don't downconvert the lvlib, then how I can I read it in the LV 8.2,
Is there any other option ??
Message 6 of 12
(4,492 Views)
Hi Guys,
this would be the solution for downgrading an lvlib an all of the VIs managed in the lib in one step to an oder LabVIEW version.
Define the source path of the lvlib. Define the path where the older lvlib and its items should be stored. And define the LabVIEW version.
This Creates a copy of the lib in an older version with all its items.
Greetings from austria
Andreas
Message 7 of 12
(3,981 Views)
@AndreasKr wrote:
Hi Guys,
Andreas
Replying  7 year old thread?
Did you run that code?
Last I looked you could not back save anything that was password protected.
Ben
Message 8 of 12
(3,976 Views)
Hi Ben,
if you have the password in your password cache it downconverts smoothly.
If you do not have the password and you start the conversation VI then you will
get a promt to type in the password. (see screenshot)
If you do not have the password than you cannot convert it.
Andi
Message 9 of 12
(3,968 Views)
@AndreasKr wrote:
Hi Ben,
Andi
And you have the passwords for LVlib ???
Quoting from the Musical Grease "Tell me more Tell me More!" (Summer Dreams ???)
Ben
Message 10 of 12
(3,965 Views)
