02-05-2010 12:21 PM - last edited on 02-01-2012 09:03 AM by JordanG
Please use the Version Conversion board to post any requests to upconvert or downconvert your VIs.
In your post, please indicate:
Source LabVIEW version
Target LabVIEW Version
**Once converted, please mark the thread as Solved by selecting "Accept as Solution".
Please remember this is not a space for code discussion. This is just a space for you to post the VIs you need to be converted to an older or newer version of LabVIEW. If an issue arises where you need further assistance after the conversion has been completed (for instance, if you need the converted
VI to be removed from the forums) please select "Report to a Moderator."
02-09-2010 08:12 AM
Can someone help me to convert these Vi´s in an newer version ? They are written in 5.1 and here we have only 8.5.1
So it would be nice if someone can convert it for me.
thx
02-09-2010 08:45 AM
03-01-2010 10:45 AM
Could I get the following two 8.6.1 VIs converted to 7.1
Thanks!
03-01-2010 11:30 AM
Hi errante,
not so much luck on downconversion:
One VI (stimbit...) looses a lot of functionality because of unsupported features, the other doesn't even downconvert (WMP..., I got a lot of "insane" errors). The 3rd one is mainly a picture of code
03-01-2010 02:18 PM
GerdW,
THANKS!
03-02-2010 06:01 PM
In downconverting from labview 8.6 to labview7.1, I ran into ignorance in my coding abilities or a compatibility issue.
In 8.6, under 'RegEvents' there is a 'Signal' option followed by 'signalType'; however, in 7.1 I am only able to evoke a 'Signal' option.
Is there a solution?
errante
03-02-2010 10:30 PM
03-03-2010 08:24 AM
Can someone be so kind as to convert the UART.zip to a version that i can open with 8.2?
http://decibel.ni.com/content/docs/DOC-1290
Adam
03-03-2010 09:12 AM
