Doubt in DAQ mx
I am virtually using DAQ mx in my application. That is a Analog 1 channel,1 sample .I am plotting that value in a chart. Whan i am running my VI,mx starts  from 4.94. How can i set it to start from zero ? Please someone help me ?
(2,364 Views)
HI CLAD,
you could "manually" subtract the offset.
Maybe there are other reasons for the offset? Differential or single ended measurement? Proper signal grounding?
(2,358 Views)
I am using RSE configuration.Why it shows frome 4.5? Can you please explain ?
(2,354 Views)
What is connected to the DAQ?  Are you reading the right channel (I know, it would be stupid, but I've done it)?
GCentral
(2,334 Views)
what ????
(2,332 Views)
