12-02-2013 04:51 PM
Hi all,
I was wondering if there is a quick way of showing one digit numbers between 0-9 as in 00-09.
Best,
Kutal.
Solved! Go to Solution.
12-02-2013 05:11 PM
Display Format of your numeric indicator. Right click and go to properties, choose the Display Format tab. Choose the Floating Point, with minimum field width of 2, and Pad with zeros on the left. Then in Data Entry tab choose the range to be from 0 to 9 with coerce if outside that range, and increment of 1.0 if you are using a double.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
12-05-2013 06:36 PM
Thanks a lot for the message, do you have an idea to convert this two digit numbers to string without losing precision
12-05-2013 08:19 PM
Format into String.
12-05-2013 08:21 PM
12-05-2013 08:28 PM - edited 12-05-2013 08:30 PM
Did you set the format string code properly?
Right click on the function and select Edit Format String.
12-05-2013 11:22 PM
Just as RavensFan suggested 😛 Check the image below, if still nor clear.
