Does vision assistant 2011 and 2012 provide normalized cross correlation?
Does anybody know whether 2011 or 2012 version of vision assistant is with normalized cross correlation function?
I would like to get the normalized cross correlation of two images. Somehow I couldnt find it. I think it should be in "filter". But I can only see smoothing, edge detection and convolution there.
I have read a manual like file which says it is located in "filter" but somehow I just couldnt find it. If someone is sure that this function is coming with newer version of vision assistant please let me know.
Thanks and happy new year!
(2,480 Views)
I am using LV 2015. I have looked at the Vision Assistant, but could not find the normalized cross correlation function in there, too.
But if you go to Functions Palette > Vision and Motion > Image Processing > Filters, you can find IMAQ Correlation VI which computes the normalized cross correlation between two images. And as far as I can see from the NI Vision Help, it is available from a version prior to yours, so you should be able to use it with 2011 version.
As a side note, you can get more responses if you would post your questions related to vision under the Machine Vision Board.
(2,439 Views)
Normalized cross correlation is not in Vision Assistant. I filed Corrective Action Request 624062 to address it in a future version of the software.
(2,348 Views)
