03-06-2017 05:01 AM
Hello to all.
I would like to use this graph in Labview but I don't know it it is exist:
Where I would give "line" and (x,y) coordinates.
Thanks a lot.
03-06-2017 05:17 AM
03-06-2017 05:18 AM
03-06-2017 05:37 AM
Thanks a lot for replying.
Where can I find the example you post in .png to open with labview?
Thanks a lot
03-06-2017 05:52 AM - edited 03-06-2017 05:53 AM
I build it myself, you may use this snippet
03-06-2017 08:14 AM
Thanks a lot.
I have another question:
I would like to do the next.
When X coordinate is 100, then I would like to remove first point and introduce the new point in x=101.
Do you understand?
Thanks again.
03-06-2017 08:33 AM
So you want a Chart with a buffer set to 100 ?
Change the Waveform Graph to Waveform Chart.
Or maybe a ringbuffer?
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/da/pg/1/q/ring%20buffer/
