Does the red dot in the attached VI affect the speed or not?
My VI has a lot of controls. If one control is defined as typedel, when the typedef connects to the other controls, it will shows the red dot. How can I get rid of the red dot? Does the red dot in the attached VI affect the speed or not?
Thank you,
(2,724 Views)
Accepted by topic author Shijie
Make the controls/indicators that you have it wired to also the type def.
The coercion does cause slight slowdowns since there is a conversion involved.  Only in the tightest of loops would you actually notice it.
GCentral
(2,709 Views)
If the coercion is simply between a typedef and a non-typdefed value with the same representation, there should be no speed penalty because no conversion is actually necessary. (Note, I haven't actually looked at the VIs posted here, so I don't know if that's the case in this situation.)
(2,689 Views)
