02-12-2016 12:22 AM
http://zone.ni.com/reference/en-XX/help/371361M-01/lvcomm/sv_dynamic_read/ says, "Caution If you use this function to access a shared variable without first opening a connection to the variable, LabVIEW automatically opens a connection to the variable. However, this implicit open operation can add jitter to the application. Therefore, National Instruments recommends that you open all variable connections with the Open Variable Connection function before accessing the variables."
This makes sense for variables hosted on a different machine on the network.
However, I was wondering about variables hosted on the machine that performs the reading. Does opening the connection beforehand provide any advantages? (ignore the possibility of reusing the same code on a different machine).
02-15-2016 11:13 AM
Hello JKSH,
Even when accessing the variable through the host machine opening the connection is recommended. These types of variables need to be addressed and connected to, it may take less time to connect to the variable from the host machine, but it still can add jitter to your program execution.
