11-02-2006 11:32 AM
11-03-2006 02:12 PM
11-03-2006 02:42 PM
11-04-2006 06:56 AM
11-04-2006 03:17 PM
08-03-2010 10:32 AM
Could you tell me more about your calibration and Metcal? Thank you. qing.shan@ge.com
08-03-2010 10:35 AM
PACE5000 from GE Druck will do the job. LabVIEW drivers are available in mid August. qing.shan@ge.com
08-03-2010 10:36 AM
08-03-2010 11:07 AM
The Druck is a good choice. I've used both the druck and the mensors and frankly, druck has better support- the integration to LV is trivial for either instrument.
08-03-2010 11:38 AM
I've used the Mensor PCS-400 and have built my own Labview drivers for it. It isn't very complicated at all. Just sending commands to the unit. Commands are taken right out of the Mensor manual. Its been while since I've used it, but I think the Mensor uses GPIB communications
We also used the 6100 for reading pressure because it was very accurate. I think this unit requires serial communications. But building Labview drivers was very easy. Again, just commands taken out of the manual. Pretty much just a read command is all that we needed. So we would set the PCS-400 to a certain pressure, and then read the 6100 to get a more accurate reading of the actual pressure.
