02-18-2012 06:07 PM
Hello everybody,
For using in image construction, I need to divide a large 2D array into groups of rows and show one block at a time.
As an example;
In attached .vi, I get only the last 2 rows and can not see any intermediate step.
How can I display these steps?
Any other idea for dividing the array?
Thanks in advance,
Mittani
Solved! Go to Solution.
02-18-2012 06:28 PM
I think you may want to wire your index and length to "i" not "N". Doing this causes the length of the subarray to vary also.
You do not need the sequence structure or the local variable. Just use a wire.
Lynn
02-19-2012 03:01 AM
How can I keep the size of the sub array constant?
The subarray should contain only two rows. In this case the subarray size increases and in the end becomes equal to the source array.
Mittani
02-19-2012 10:41 AM - edited 02-19-2012 10:42 AM
By wiring a constant to the size terminal, maybe? Seems obvious! 😄
02-19-2012 01:19 PM
Yes, you are is rigt:)
Thanks a lot.
