03-03-2014 08:30 AM - edited 03-03-2014 08:59 AM
Hi!
I want to write a program which will use some external data to build a map of a track. I have images of each section of the track and I want to display them in such a way so a map of track is created. I don't know how to set the position of a picture so end of one section matches the beginning of the next.
Is there a way in LabVIEW to specify a x & y position of separate images? Tricky part is with corners, so need to rotate a picture as well. What are my options?
It is a track for Scalextric car racing game for those who are interested.
Kamil
03-04-2014 02:56 AM
Hi kropiak,
you could load that image data and place it in a 2D picture indicator arbitrarily to build your track. You need to calculate xy positions on your own, probably the track parts a following a certain raster size…
To rotate images you should search the forum, there are similar questions already answered!
03-13-2014 06:49 AM - edited 03-13-2014 06:53 AM
Hi again! This is what I have achieved so far - see attached VI. In order to take it to the next level I need to solve one problem. I can't display multiple pictures onto the picture display. The program so far is to just display one picture, move the origin by -25,-25 and display second picture. As soon as second picture is displayed, the first one disappears.
I use 'EraseFirst' property node with '0' input which should prevent the display from erasing but it doesn't seem to help.
Any hints or help with why this is happening?
Also Note that I have a student version of the LabVIEW
Kropiak
PS. run the program first, stop it and then run it again to make it work... Just noticed that
03-13-2014 07:54 AM
Hi kropiak,
two big problems:
- right now you load a new picture and overwrite the old 2D picture indicator: so you can never keep the previous picture…
- you seem to move the origin of the 2d picture. You rather want to place the sub-images at different positions in the full 2d picture image…
Other problems:
- too many local variables! THINK DATAFLOW!
- your way of building a path is rather buggy. Use path functions instead!
- make your selection buttons a radio button…
In the attachment I just made some of those mentioned changes, you have to proceed further…
03-13-2014 11:25 AM
Thanks for the reply and showing me my problems! I still struggle with getting my head round LV 🙂
Your changes and suggestions helped me. I will now try to build the a track. I will keep updating about my progress and problems if I have any 🙂
