06-29-2016 01:33 PM
Oh, ok, the picture wasn't showing up for me before. Looking at it now, hmm, I'm not sure what the problem is. Have you tried using the probe tool? When you probe it, is the array empty or does it have data in it?
06-29-2016 01:38 PM - edited 06-29-2016 01:41 PM
@ZMK16 wrote:Here is another try to display at least one running signal in a Waveform graph. The Graph is not showing a signal. The X and Y Axis are autoautoadjusting but no graph is displayed.
Can you attach the actual VI instead of a truncated image? Remove all unecessry code and incude typical simulated data so we have something tio play with.
Is there a reason you convert to a 3D array, but never get out of the single plane, seems completely redundant and unecessary?
If you want to display some data over the entire range, but also new data as it arrives, initialize a 2D array of sufficient size with NaN and place the permanent data into certain rows. Now you can update with the growing data by replacing the NaNs in the relevant row.
06-29-2016 01:49 PM
Here's a very crude example that can potentially give you some ideas.
06-29-2016 02:23 PM
