08-04-2015 09:11 AM
Hello
How can i display multiple spreadseet on one XY Graph ?
i'm using this method for single file :
Solved! Go to Solution.
08-04-2015 09:20 AM
You can just use a FOR loop. Autoindex on your array of files. Inside the loop, you just read the file and process it as you already do. Then you just append the array. If you have LabVIEW 2013 or later, you can use the Concatinating Tunnel for the output array.
08-04-2015 09:29 AM
Hello crossrulz
may i ask you show this for two files .
08-04-2015 09:53 AM - edited 08-04-2015 09:55 AM
Don't know how to follow directions?
08-04-2015 10:24 AM
I like the use of subVI and non-functional snippet.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-04-2015 10:55 AM
James.Morris wrote:I like the use of subVI and non-functional snippet.
The OP already had that part figured out and I was too lazybusy to recreate it. Besides, he just asked for an example. No reason to do their job for them.
08-04-2015 11:04 AM
Yup, I figured as much.
Cheers
08-04-2015 10:51 PM
This is what i have done
it's really intresting that The color of the plots automatically got changed
as you see here address is constant and number of file too.
now i'm working on user just select the folder and the code automatically display all file in the folder .
08-05-2015 11:33 PM
Hello
How can get the plot corresponding color ?
