01-30-2015 05:29 AM
Dear friends
How a Display and Graph can update with a manual adjustable time control? Not using loop delay.
01-30-2015 05:48 AM - edited 01-30-2015 05:48 AM
Hi Alex,
you need to use a loop delay anyway when you want to update an indicator at a regular interval!
But it doesn't need to be the very same loop as your DAQ loop. You could use a parallel running loop with it's own timing…
01-30-2015 05:57 AM - edited 01-30-2015 05:58 AM
Ok.
My problem is exactly the parallel processing. I've used while loops in parallel and the data go by local variable. I think it isn't a good practice, maybe there is a better way avoiding local variable to pass the data.
01-30-2015 12:18 PM
look in this forum for AE or FG (action engine or functional global)
