11-13-2012 03:41 AM - edited 11-13-2012 03:41 AM
I'm designing a bed that has the function of giving the pressure pattern of a patient. Now I'm testing some pressure sensors but I notice some problems in Labview.
I have an array of 4x4 of pressure sensors. When i want to display them in an intesive graph and an array they are displayed differently. If the array display the pattern correct, the view in the intensive graph is 90 degrees rotated (see attached figure). I've tried to invert some signals in the properties of the graph but it didn't work.
Does anyone has some idees?
Or does someone has a better idee of processing these signals?
11-13-2012 03:51 AM
Hi Frank,
to answer your question: use the Transpose function found in the array palette.
To help you write better VIs: disregard the DAQ assistent ExpressVI, use "standard" DAQmx functions, read your signals as 1D array and use some other array functions to reorganize your data for viewing...
It just looks awkward what you have posted 😄
