05-19-2017 03:28 AM
I'm trying to import some "Greek" words from an Excel file as part of a translation application, which replaces all English words with Greek words(PropertyNode->Caption->Text).
But the problem is that they show up as questionmarks instead of letters: Size distribution[mm] => ?st???af??[mm] (Should be: Size distribution[mm] => Ιστοριόγραφο[mm])
I have tried to switch the Font to "Symbol", but still the words shows up wrong !
The Excel file shows the letters(words) correctly, so it seems to be something in LabVIEW that need to be adjusted.
Any ide? 🙂
Ps: The application works correctly for other languages which does not contain symbols, like german, french, spanish, etc...)
05-19-2017 05:11 AM
I believe this is related to the Unicode question. There is (as of LabVIEW 2016) limited support for Unicode in LabVIEW, as described here.
05-19-2017 10:07 AM
Post what you have already done (VI not image) and we will try to help you.
05-19-2017 10:54 AM
For me it is working fine...
Did you use an UTF16LE string?
05-23-2017 05:21 AM - edited 05-23-2017 05:24 AM
Your example works fine with the text strings(constants) .
But it does not work when trying to import from a .csv file, so i guess the problem is the .csv file format (or something like that).
I have attached the LabVIEW VI and the .csv file
05-24-2017 09:18 AM - edited 05-24-2017 09:20 AM
You extracted ASCII characters instead UTF16LE characters from yours CSV file.
When you wrote those strings with InterprAsUnicode ON,the first two ASCII characters are interpreted as U+4361 (UTF16LE) or U+6143 (UTF16BE) and so on.
http://www.fileformat.info/info/unicode/char/6143/index.htm
Instead, use a text file (second message):http://forums.ni.com/t5/LabVIEW/Multilanguage-user-interface/m-p/2744846/highlight/true#M810815
05-24-2017 09:33 AM
Oups, I apologize.
You use a UTF08 text file (I use the same) but you forget to convert UTF08 to UTF16LE. Use "UTF8 to UTF16LE.vi" from "VIs String Conversion.zip"
http://forums.ni.com/t5/LabVIEW/Unicode-characters-in-TDMS-file/m-p/3585021#M1003909
PS Those VIs came from Babel
https://forums.ni.com/t5/LabVIEW/undocumented-function-quot-text-to-utf-8-quot/td-p/512911
05-26-2017 02:23 AM
Hi again,
Not sure if I'm using the "UTF8 to UTF16LE.vi" correctly, but I tried placing it between the "Index Array" and the "Property Node" (see picture).
Or am I supposed to convert the entire .csv file first (using this vi)?
05-26-2017 09:17 AM - edited 05-26-2017 09:27 AM
06-06-2017 04:57 AM - edited 06-06-2017 04:58 AM
Hello again,
It works as intended for changing Caption/BoolText 🙂
But it does not work for changing TabCaption (i'm doing this programmatically using Property "Page", which works fine for ASCII).
Any idea how to format (InterpAsUnicode) for TabCaption?
