Disappearing Tool Palette - LabVIEW 6.i ???
Has anyone else found that the tool palette disappears when dragged or
moved in LV 6.i ?!?. This also occurs when any other palette is dragged.
Any ideas on how I can fix this problem ???
M.
(3,214 Views)
Humm
Make sure you haven't disabled window content while dragging. Right click on your desktop>>Properties. Go to 'Effects' Tab, and check "Show window content while dragging".
Can't think of anything else.
A Rafiq
(3,214 Views)
I'm afraid this doesn't improve things, the palette still disappears
when dragged.
I might point out that this problem always occurs with my Win95, NT4.0
installations, but it doesn't seem to occur with Win98 !!?
Thanks for the help,
M.
A Rafiq wrote:
> Humm
> A Rafiq
> National Instruments
(3,214 Views)
R U using LabVIEW 6i?
If u understand it correctly, you go Window>>Show Tools Palette. Does it pop up correctly? and when you click on the title bar and drag it disappears??
(3,214 Views)
Exactly
> disappears??
(3,214 Views)
Anyone see this same behavior in LV 2011 SP2, on Windows 7..?
When I resize or drag the Controls or Functions palette, the palettes (and the tool palette) disappear. The LV Menu becomes non-responsive, and there is no way to reopen the palettes.
I have tried re-installing all the NI software, but the re-installed version behaves the same way.
Anyone see this one before...?
D.
(2,653 Views)
Same problem LV 2013
Windows VISTA 64 Bit
(2,595 Views)
