05-10-2012 05:05 AM
I want to lock the scale of a graph on the front panel, which should display the y-scale from 0 to 6.
So I've disable the autoscale Y-axis. But at the run time I can still change the max tick label manually.
How can I lock the tick label on the scale without using the property node?
Thx,
Wilbur
Solved! Go to Solution.
05-10-2012 05:23 AM
You have a property called Editable in the Y scale properties of the graph set that to False.
05-11-2012 06:09 AM
Surely it works,thanks.
Still I have to write it in the block diagram. But there is no setting of the properties?
