11-13-2015 02:33 PM - edited 11-13-2015 02:33 PM
This is asked in the spirit of making an appealing UI. I have a text box that displays various bits of data. That part works fine. What I'd like to do is make it impossible for the user to select the text within the box. A mouseclick inside the box would behave like a mouseclick on a vacant part of the UI window.
Right now, I'm fooling around with the "Get Image" invoke node with the intent of creating an image of the indicator and then displaying it instead. Is there an easier way?
Solved! Go to Solution.
11-13-2015 02:36 PM
Just disable it. If you always want it that way, then right-click on it and choose Advanced->Enabled State->Disabled. There is a similar property node if you want to do it programmatically.
11-13-2015 02:39 PM
11-13-2015 02:46 PM
@crossrulz wrote:
Just disable it.
I can't believe I didn't try that. Thanks.
