01-09-2014 09:11 AM
Hi All,
I am using 'Export Image' Invoke function of Picture control to export Picture control's data to Clipboard. The function performs as it is intended to but in 64 bit version of LabVIEW, I hear a ding when I use this function. I do not hear any ding in the 32 bit version. Also, there is no ding in the development mode, I only hear it in the 64 bit EXE.
Is this a bug?
01-10-2014 12:30 PM
I have a couple questions that may help narrow down troubleshooting. Do you hear the ding on the 64-bit executable on other machines too or just the development machine? Also how have you determined that the invoke node is the part of the code causing the ding?
01-10-2014 01:25 PM
Yes, I hear Ding on all the other machines I run the executable.
I removed invoke node from the code and did not hear any Ding in the EXE.
01-10-2014 02:40 PM
Somewhere I posted code to momentarily turn off a sound, but that is probably like pulling the bulb from your check engine light. Does the code work despite the ding?
01-10-2014 03:18 PM
Yes, the code works despite the ding.
01-13-2014 11:39 AM
It does seem strange you are hearing a ding. I would like to see if I get the same result on my machine. It looks like you are using LabVIEW 2013, correct? And which OS?
01-13-2014 01:46 PM
I am using LabVIEW 2012 SP1 on Win 7.
01-13-2014 06:26 PM
Just wanted to let you know I found the same result as you.
This was reported to R&D (# CAR 444840) for further investigation. Thanks for the feedback!
01-14-2014 10:01 AM
Thanks for reporting it to R&D team.
