Digital waveform generation through external triggering by pulses on PCI 6251
Sir i want to by NI 6251 for i read it has ability to generate and acquire  digital waveform on port 0 . I want to know that can i generate waveform by external clock triggering ( by providing pulses at one line on the DAQ)?
(2,192 Views)
Accepted by topic author Ali211
Hi Ali211,
Yes you can use an external sample clock source for the digital input/output clock. You can connect the external clock source to any one of the PFI lines (PFI0-PFI15) and specify the sample clock source as this external PFI line.
There are a couple DAQmx shipping examples that you can start with. Find the examples by going to Help >> Find Examples... in LabVIEW.
DAQmx Continuously Read Digital Channel with External Clock
DAQmx Write Digital Channel- External Clock
Hopefully this helps.
Chris G
(2,174 Views)
