08-29-2014 09:26 AM
Are you talking from making a subVI? Or just branching the wire so data goes to multiple places on the same VI?
08-29-2014 09:30 AM
I am using bit Numerical control to input my decimal input. Then I am using a split number to convert that to t 16 bits and then again 2 split numbers to spilt it into two 8 bits. I want these seperate 8 bits as an input in the other VI but I can copy this whole code to the Controlling VI where I want to use these values.
Thank you.
08-29-2014 10:36 AM
08-29-2014 10:38 AM
Yes. I am putting whole code at same point. I found the solution by the way, I split the number 2 times and then created a control variable for each byte. Converted it to read and then built an array out of it,
Thank you for your help.
Cheers!
