12-04-2010 09:47 PM
Hi
I'm new to Labview. I'm doing a thesis project which simulate IC 74LS112, 74LS90, etc.... First, to simulate decade counter (74LS90), I created JK- flip flop (74LS112) which use multiple logic gates. Then I used JK-FF to build 74LS90 following datasheet of the manufacturers but it didn't work. After searching on the forum, i know that i can't design these IC using multiple logic gates because of bugs or something i dont know. So I need another way to complete my project. Does anyone have any suggestion or ideas? I'm stuck and don't know where to begin. Thanks.
Solved! Go to Solution.
12-04-2010 09:59 PM
You should probably post this question on the multisim forum?
Alan
12-04-2010 11:48 PM
Thanks for your reply but i'm using Labview to simulate not Multisim.
12-05-2010 01:42 AM
As you probably know, LabVIEW is a programming language, not a circuit simulator.
Still, LabVIEW would be fully capable of doing any circuit simulation if you don't shy away from a bit (possibly quite a bit!!!) of programming. ![]()
Since you are new to LabVIEW, this will not be easy. You should start with some tutorials, study the shipping examples, then try to design your program.
If you don't know something, you probably should not throw out unfounded and unverified accusations. Not everything you read on wikileaks about LabVIEW is true. ![]()
There is no "can't" in LabVIEW! Even if there is a bug (and I doubt there is!), there will be workarounds.
If you found a thread that describes that there is a bug, please provide a link to that thread.
Do you have a CAR #? We need information! Thanks!
12-05-2010 01:55 AM
Thanks for your reply. You're person who I'm looking for
I already post 1 message before but since no one try to help me, so i have to post this one. I'm sorry if i say something wrong but I do really need your help.
I built JK-FF which use multiple logical gates and it works. Then when I put 2 individual JK-FF in the same diagram with invididual Clock and Led, I found that the Led of the second JK-FF active when the clock is 0 and the first clock is 1.
12-05-2010 01:59 AM
I'm sorry that I forgot to attrach my vi. I spent a week to solve it but I still dont understand why. Now I'm trying another way but it take much times than the old one.
12-05-2010 02:36 AM - edited 12-05-2010 02:38 AM
Since your JK-FF subVI and it's subVI both store data in feedback nodes, you need to make them reentrant (VI properties...execution), else all calls use the same instance and the code interacts in an unpredictable way that depends on the call order.
(I have not verified your code and I will refrain from any comment. I also cannot test because you forgot to attach one if the subVIs. What is the toplevel VI? Why is there no while loop?)
12-05-2010 03:24 AM
Oops. I'm forgot one. From the beginning, I simulate these flip flop following the theory, that's why there's no while loop. First, I built 2 binary counter which using 2 JK-FF following the theory and i didn't work. I though my JK-FF has problem, so I tested them individually in the same block diagram and i found that second one works when the first one works.
12-05-2010 11:56 AM
I don't know why you think one precludes the other... ![]()
I don't know what "didn't work" and "works" means in this context. Since there is no data dependency between the two calls, the execution order is not determined and the label "second one" and "first one" is completely meaningless. You cannot tell what executes first (LabVIEW does not execute left to right unless there is a data dependency imposed execution order).
You cherry pick one scenario and say it works, but for a complete understanding of the problem, a more complete description is needed.
12-05-2010 12:37 PM
You actually were getting help in your other thread and that was before you started this thread. So don't say that no one tried to help you,
Please don't start new threads with the same question. It just divides up the answers you are getting and wastes the time of the people who are trying to help. If you don't think you got a satisfactory answer in your earlier thread, then ask the question again in the same thread adding any additional detail that might help clarify your question.
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
