10-09-2015 02:30 AM
Is it possible to perform Digital image correlation with Labview VI ?
I am a beginner with lab view and I am working on a project to integrate labview with probe station(microscope with AFM scanning tip) for recording the images for inplane deformation measurement on MEMS comb structure.
Please share the possibilities.
10-09-2015 08:39 AM
First, learn LabVIEW. Take a course, if one is offered. Study multiple on-line tutorials (there are a bunch listed in the upper-right corner of the Forum). Find a LabVIEW "guru" who can take you on for a few weeks as an "apprentice". Alternatively, hire a skilled LabVIEW programmer.
10-09-2015 08:40 AM
Oh, and, yes, it is possible to perform Digital Image correlation with LabVIEW.
10-09-2015 10:27 AM
thank you for your suggestions and if DIC is possible with AFM pictures then can you please share me your ideas.
BR
Ravi
10-12-2015 05:19 AM
Hi Ravi,
as far as i found out yet there is no LowLevel DIC-Function in LV or its Toolkits. There are VIs using the DIC Algorithm thought. What exactly do you want to do with DIC? The Vision Development Module 2015 contains an Object-Tracking-VI wich should be using DIC. If you want to track something this might be what you need. But notice, that the Vision Development Module is a purchasable Toolkit for LabVIEW. If you're not sure you can download and install a 7-Day-trial and see if it fits your needs.
If Object-tracking is not what you want to do, please let me know.
Jan Göbel
NI Germany
10-13-2015 08:02 AM
Hi Göbel,
I have to measure inplane-displacement measurement on MEMS structure using AFM images and the deformation is in nanometer range. At a later stage i would like to integrate the system(Probe station with source meter) for capturing the picture and for performing correlation to know the displacement in these two images with Labview. For example I have attached two such pictures and I would like to perform correlation between these two picture.
10-14-2015 07:15 AM
Hi Ravi,
I'm not absolutely familiar with the exact Algorithm you need, but could this be the VI you're looking for?
http://zone.ni.com/reference/en-XX/help/370281W-01/imaqvision/imaq_optical_flow__lkp/
It can calculate the movement of parts in your Pictures from frame to frame.
Have you got the Vision Development Module? As is said this is a purchasable Toolkit. But if you want to try the VI you can simply download is for evaluation and got 7 Days time to try out the Function.
Jan Göbel
10-14-2015 07:16 AM
Here is a little demo of what you can do with the function:
10-26-2015 04:33 AM
Hi Goebel,
I am working on Imaq correlate vi for seeing the difference between two images. I have attached the VI here. I would like to know how to interpret the output of vision imaq correlate in the form of values in pixel arrays or to know what is the difference between two images in pixel ( shift in pixels from these two images) as I only see the output picture but I want to know the difference in numeric value between two images.
