Developing a Generic Report Wizard
Hi
My application requires to develop a generic report wizard, using  labview.
which allows the user to choose the required signals and respective contents
and layout pattern,
can anybody suggest any idea as to how to start on this, or has anybody
earlier worked on this kind of development using labview, if so please can you
help me out
rags
(2,497 Views)
Hi
If you want to develop a wizard, use the LabVIEW Wizard template, which was posted in another thread.
It uses a tab-control which pages are switched using a button. Just have a look at it.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,490 Views)
Hi Becktho,
Thanks for the reply and suggestion, i need a basic idea as to how start of this,
i went throught the wizard dialog what you had sent, can you be specific as to how
can it  be used, for my application, where in, the user has the options to select the
signals and contents,  i am actually pretty confused, cos i haven't  done anything ,
like this before. so can you guide me.
thank you
rags
(2,481 Views)
The next steps would be to place all the controls and indicators on the tab, so that the user can make all the decisions.
Due to the fact that you want to have a wizard, try to group these controls and indicators topic-wise, so that you have a tab-page for each topic.
Thomas
Using LV8.0
(2,477 Views)
Hi thomas
Thank you for the guidelines and reply.shall get back to you  incase of problems, have a nice day.
rags
(2,476 Views)
http://www.ni.com/devzone/lvzone/dr_vi_archived5.htm
This is the link to a "Dr. VI" article about developing a wizard. It refers to the vi I attached you.
Thomas
Using LV8.0
(2,472 Views)
