Tell me please, how I can get brightness of pixels at points that are located on the circle every 10 degrees, It meansmustbe36 points on the circle.. First of all converted into gray tones, thendrawa circlespecifiedradius in the studied area, thendetermine the coordinates of36points then determine the brightness at predetermined points
If you know IMAQdx, then start writing the code and come back (posting your code) when you get stuck. If you do not know IMAQdx, it is one of the most challenging parts of LabVIEW as there are a lot of "picture" and "camera" conventions that you'll need to learn, and not a lot of tutorial material. There are (some) examples included with LabVIEW, but because of the (relative) complexity of Image Processing, I would strongly recommend that you have at least a year of LabVIEW experience and/or a CLAD certification before diving in.
