03-31-2015 11:29 PM
I am writing a basic analog input function, which will be triggered via a start trigger sent by another instrument. Is there a way to programmatically deteremine if the Analog Input task has been triggered? I would like to have a Boolean indicator that shows "True" after the Analog Input task is triggered, but I couldn't find out how. Does anyone have a suggestion? Thanks!
04-01-2015 04:23 AM
Is this a continuous acquisition?
I am not aware of a function querying the trigger state of a task. Nevertheless, i don't think this is necessary as you usually start reading right after starting the input task.
So in case a trigger is late, you will/should run in a time out error. Otherwise, you will get some data which is a clear indication that the task is running....
Norbert
04-01-2015 07:41 AM
