05-08-2013 12:41 PM
Hi!
I'ts the first time i'm posting a question in the NI forum, so i hope i'm doing it right.
I'm using labview 2012 and I'm Trying to create and store timestamps from a real-time Aquired Data. I have a chart that display the voltage aquired from a NI USB-6343 X series on the Y-axis with the Absolute Time on the X-axis. Then the user must click on the chart and display a option for creating a timestamp with the x value from the place that were clicked and a name to that instant.
I'd apreciate any help.
Best Reagrds
Marcelo Nobre
05-09-2013 08:33 AM
Hi Marcelonobre. How are you?
So I found a documentation similar. See if its what you need.
http://digital.ni.com/public.nsf/allkb/191A70953A91663D862574F00057423D?OpenDocument
Regards.
05-09-2013 01:30 PM
Hi Erick.
Thanks for the fast reply!
Is there a way to do it on a Waveform Chart? Because i'm aquiring the data on real time and the Waveform Graph, as far as i know, doesn't support that. Is there a way to do it on a WaveformChart?
Best Reagards
Marcelo
Ps.: Vou ver o forum em portugues! 🙂
05-10-2013 06:24 AM
Hi Marcelo.
In the Waveform Chart is not possible. Because the cursor function only has in he Waveform Graph.
Regards.
05-10-2013 07:01 AM
