04-04-2014 01:42 AM
Hello!
I am having some issues with a Denver Instrument TP-12 analytical balance.
I have set up the balance and made sure that all the VISA settings match in LabVIEW.
I do manage to read accurate weight from the balance, and the read buffer works correctly, but every 30 seconds or so the read buffer gets filled with gibberish (random non-numeric characters) and so the numeric data (after converting from String to Numeric) is read as 0.
I contacted Denver Instrument (now Sartorius) and was told that the problem probably lies in LV.
Attached is the VI that I am using as well as screenshots of the read buffer when it reads the gibberish.
Any advice as to why I am having these weird reading and what I can do to either prevent them or a method to have the numeric data ignore the spikes in the reading would be GREAT!
Thanks-in-advance,
4Strings
Solved! Go to Solution.
04-04-2014 07:23 AM
In order to know if LabVIEW is the culprit of this behavior, it might be very helpful to use this architecture :
and tell us if you see the same behavior.
04-04-2014 01:35 PM
It worked!
Thank you SO much!
-4Strings
04-07-2014 12:39 AM
Thanks for your feedback !
Producer/Consumer is one of the most powerful architecture for data processing/logging :
- One loop (one process) to acquire datas
- One loop for processing/logging
By using this architecture, you are sure to remove 99,9 % of acquisitions issues.
Cheers,
04-07-2014 05:11 AM
04-08-2014 08:42 AM
Hi 4Strings,
Mathieu_T had a great advice when he recommended the producer/consumer loop. If you want to pass multiple datatypes with the queue structure, I would recommend grouping the data into a cluster or an array, since a queue can only handle one data type (e.g. a cluster containing a string and a double).
There's a bit more information on the producer/consumer loop here: http://www.ni.com/white-paper/3023/en/
