12-08-2015 07:43 PM - edited 12-08-2015 07:49 PM
You have to add the data through the cluster to the chart (waveform graph).
The data you want to display in the graph, but only about 1,000, but I would like to delete from the old data in the order if it exceeds 1,000,
Any way do you have?
Currently, it is not be deleted, the number of data will stop is quite a lot to be processed.
Nice to meet you
12-08-2015 07:59 PM
How is your code set up? The graph data is a waveform with a certain size array of points. So you can work with that array and the t0 value to get your new graph
It sounds like what you want is a Waveform Chart. Give that a try instead of a graph.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
12-08-2015 08:15 PM
