Default table cell size
Hi
I am working on the table, I resize cells in the table and save it. But after I open the vi again, the cell size change to labview  default size.
Is There any way to save the change the cell size. It means that I will not resize itself to default size.
Gary
(2,223 Views)
Hi Gary,
I have attached a peice of code which will set all the cells in your table to a default size. Incorporate this into your code and it will set the cells to a size you specify.
Good Luck!
Nathan
National Instruments UK & Ireland
(2,193 Views)
