05-27-2014 07:24 AM
Hello everyone !
I have a cRIO-9074, and I'm trying to decode an IRIG-B signal. I have the module NI-9402 for input.
I know that there is an example here http://www.ni.com/example/28396/en/, but it is old, for a PXI and it doesn't work with the last version of Labview...
Does anybody have an example which work, or a begining of an answer?
Thanks !
Simon M
PS : sorry for my bad english
05-28-2014 10:03 AM
When you migrate the code, What kind of problem do you have?
I can share with you another example (non official, and I do not supported this code) but you could use it.
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
06-02-2014 03:31 AM
hello !
Thank you for your answer !
The problem is there are some connections which are not possible. I think the software has evolved and now, and the connxions are note available because it's not the same types of data...
I will see your code !
Regards
Simon M
06-02-2014 03:47 AM
Oh ! This example seems to work ! All the connections are okay.
Thank you verry much ! I will try to study the code to configurate my cRIO now.
Regards
Simon M.
09-03-2014 03:46 PM
can you please publish the example?
09-04-2014 02:55 AM
Which one do you want?
Samuel G. | GEMESIS
09-04-2014 05:46 PM
You wrote “I can share with you another example (non official, and I do not supported this code) but you could use it.”
I would like to see a working code for IRIG-B Decoding in Labview
I am checking an option to record IRIG-B signal with audio card along with some events and then to synchronize different sources offline.
09-05-2014 02:33 AM
Hello, you could find the code in attachement of my last post (05-28-2014 10:03 AM).
Regards
Samuel G. | GEMESIS
03-19-2018 05:00 PM
I sounds like you got this working for the NI-9402. Did you just use his latest code (and update the signals for your hardware)? Did you have to make any other changes?
Phil
