Decimal string to Ascii (hex) string
i want to convert a decimal string like this "12345" in Ascii (hex) string like this "3132333435".
How can I make it?
regards
Schwede
(5,237 Views)
Accepted by topic author Schwede
This is one way to do it.
(5,232 Views)
 i want to convert a decimal number like this "1234" in hex string like this "1234"..
(4,701 Views)
Please attach what datatype you have. Do you have a numeric integer datatype as input? In this case the formatting of it is irrelevant and your use of "decimal" just confuses the issue. All you need is "Number to decimal string".
Please clarify if you need something else. Typically it is not advised to add a new and different question to the end of an old thread that is already marked as solved. Start a new thread next time.
(4,686 Views)
Hi All
I am trying to converter 4 bit hex string to number. I know the right results. But I do not know how converte. Please see the attached vi
Please help me.
(4,224 Views)
duplicate post, continue here
(4,220 Views)
