01-22-2015 09:57 PM
Thanks & Regards,
01-22-2015 10:28 PM
Hello PBP,
You can keep open those clone VIs and make indicators where ever required to see current ongoing process inside the code. This seems to be the simplest way, but it requires multiple times of memory of PC as they use clones for each instance.
DCKAN
01-22-2015 10:33 PM
Hi PBP,
You can even keep probes by opening clones and its block diagram..
DCKAN
